I’d like to use Anthropic Claude as a custom AI provider in eM Client 11 Windows. (11.0.1201)
My settings under Settings → Artificial Intelligence → General → Custom AI Provider:
- URL:
https://api.anthropic.com/v1 - API key: my own valid Anthropic API key (active, with credit) – working with curl!
The problems:
- The “Primary model” dropdown stays empty, so I can’t select a model.
- “Test connection” returns Error 400.
I’ve also tried https://api.anthropic.com/v1/ and https://api.anthropic.com, with the same result.
Could you tell me:
- Is Anthropic supported via its OpenAI-compatible endpoint, and which base URL does eM Client expect?
Thanks in advance!
