I have eMClient installed on my Windows desktop and two Android devices. There is the native calendar and I have created two extra calendars for myself and my wife. These do not show on my Android devices. If I create an event on the desktop email, these do not show on my Android devices. It is probably operator error, what am I doing wrong?
If they are eM Client Desktop app “Local account calendars” they wont show or sync in the mobile app Local calendar section. Only cloud calendars.
However if the two Desktop calendars are IMAP, Exchange, Office 365 or iCloud calendars, then using the mobile app press “Menu” top left and press “Settings” . Then under Accounts press “Add new account” part way down and add your two extra calendar accounts either via the automatic account wizard or manual setup option depending on your calendar providor.
Alternatively “if there is nothing in the mobile app Local folders”, then suggest first press “Menu” top left and press “Settings”. Then under Accounts, remove whatever accounts you have already setup.
Then using eM Client Desktop go to “Menu / Tools / QR Export” and select all your three accounts. Then when you get to the end of the QR Export wizard, “open the mobile app” and press “Menu / Settings / Import-Export” and select “Import via QR Code” and scan the bar code which will import the desktop account settings which should then include all your three calendars.
Many thanks, I will work through that.
