After Windows reinstall, I setup eM Client again and used the old /User/AppData/Roaming/eM Client Data (copied old files into the folder). I then had my old email archive but whenever I try to create a new message or answer one in my inbox, eM Client immediately crashes and ask for a restart. After restart, I experience the same problem again.
What data are needed after new setup of eM Client so that the locally saved email archive (mail_data.dat) is available but eM Client does not crash when creating a new message.
Below the error message after crashing:
eM Client (6.0.21040.0)Windows: Microsoft Windows NT 6.2.9200.0, Framework: 4.0.30319.18449
System.Data.SQLite.SQLiteException (0x80004005): SQL logic error or missing database
no such table: security_index.SecurityProfileItems
bei System.Data.SQLite.SQLite3.Prepare(SQLiteConnection cnn, String strSql, SQLiteStatement previous, UInt32 timeoutMS, String& strRemain)
bei System.Data.SQLite.SQLiteCommand.BuildNextCommand()
bei System.Data.SQLite.SQLiteCommand.GetStatement(Int32 index)
bei System.Data.SQLite.SQLiteDataReader.NextResult()
bei System.Data.SQLite.SQLiteDataReader…ctor(SQLiteCommand cmd, CommandBehavior behave)
bei System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior)
bei System.Data.SQLite.SQLiteCommand.ExecuteDbDataReader(CommandBehavior behavior)
bei System.Data.Common.DbCommand.System.Data.IDbCommand.ExecuteReader()
bei MailClient.Storage.Data.SQLite.DbRepository1.FindByOids(IList
1 oids)
bei MailClient.Storage.Data.SQLite.DbRepository1.FindByOid(UInt64 oid) bei MailClient.Storage.Application.Security.SecurityProfileCollection.FindSecurityProfileByOid(UInt64 oid) bei MailClient.Accounts.Db.MailAccountConfiguration.get\_SecurityProfile() bei MailClient.UI.Forms.formSendMail.get\_securityProfile() bei MailClient.UI.Forms.formSendMail..ctor(IMail mail, SendResponseType sendResponseType, MailAccount mailAccount) bei MailClient.UI.Forms.formSendMail.createNew(MailAccount mailAccount) bei MailClient.UI.Forms.formSendMail.CreateNew(String mailTo, MailAccount mailAccount) bei MailClient.UI.Forms.formMain.ShowNewMessage(String mailto, Boolean useDefaultAccount) bei MailClient.UI.Forms.formMain.menuItem\_Actions\_NewItem\_Click(Object sender, EventArgs e) bei System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e) bei System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e) bei System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e) bei System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met) bei System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met) bei System.Windows.Forms.ToolStripMenuItem.ProcessCmdKey(Message& m, Keys keyData) bei System.Windows.Forms.ToolStripManager.ProcessShortcut(Message& m, Keys shortcut) bei System.Windows.Forms.ToolStripManager.ProcessCmdKey(Message& m, Keys keyData) bei System.Windows.Forms.ContainerControl.ProcessCmdKey(Message& msg, Keys keyData) bei System.Windows.Forms.Form.ProcessCmdKey(Message& msg, Keys keyData) bei MailClient.UI.Forms.formMain.ProcessCmdKey(Message& msg, Keys keyData) bei System.Windows.Forms.Control.ProcessCmdKey(Message& msg, Keys keyData) bei System.Windows.Forms.Control.ProcessCmdKey(Message& msg, Keys keyData) bei System.Windows.Forms.ContainerControl.ProcessCmdKey(Message& msg, Keys keyData) bei System.Windows.Forms.Control.ProcessCmdKey(Message& msg, Keys keyData) bei System.Windows.Forms.Control.ProcessCmdKey(Message& msg, Keys keyData) bei System.Windows.Forms.Control.ProcessCmdKey(Message& msg, Keys keyData) bei System.Windows.Forms.ContainerControl.ProcessCmdKey(Message& msg, Keys keyData) bei MailClient.UI.Controls.controlItemList
2.ProcessCmdKey(Message& msg, Keys keyData)
bei MailClient.UI.Controls.controlCategorizableItemList2.ProcessCmdKey(Message& msg, Keys keyData) bei System.Windows.Forms.Control.ProcessCmdKey(Message& msg, Keys keyData) bei System.Windows.Forms.ContainerControl.ProcessCmdKey(Message& msg, Keys keyData) bei MailClient.UI.Controls.ControlDataGrid.ControlDataGrid.ProcessCmdKey(Message& msg, Keys keyData) bei System.Windows.Forms.Control.PreProcessMessage(Message& msg) bei System.Windows.Forms.Control.PreProcessControlMessageInternal(Control target, Message& msg) bei System.Windows.Forms.Application.ThreadContext.PreTranslateMessage(MSG& msg) bei System.Windows.Forms.Application.ThreadContext.System.Windows.Forms.UnsafeNativeMethods.IMsoComponent.FPreTranslateMessage(MSG& msg) bei System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData) bei System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context) bei System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context) bei System.Windows.Forms.Application.Run(ApplicationContext context) bei MailClient.Program.<main>b__4()<br> bei MailClient.ExceptionUtils.ExceptionUtils.Filter(BodyDelegate body, FilterDelegate filter, Action
1 handler)
" rel=“nofollow”>http://emclient.com/ns/report">;
eM Client
6.0.21040.0
false
4.0.30319.18449
System.Data.SQLite.dll
100663600
System.Data.SQLite
Prepare
System.Data.SQLite
System.Data.SQLite.SQLiteConnection
cnn
mscorlib
System.String
strSql
System.Data.SQLite
System.Data.SQLite.SQLiteStatement
previous
mscorlib
System.UInt32
timeoutMS
mscorlib
System.String&
strRemain
265
4b2
100663734
System.Data.SQLite
BuildNextCommand
f6
17f
100663735
System.Data.SQLite
GetStatement
mscorlib
System.Int32
index
8
12
100663982
System.Data.SQLite
NextResult
e4
112
100663943
System.Data.SQLite
.ctor
System.Data.SQLite
cmd
System.Data
System.Data.CommandBehavior
behave
5d
71
100663757
System.Data.SQLite
ExecuteReader
System.Data
behavior
c
26
100663756
System.Data.SQLite
ExecuteDbDataReader
System.Data
behavior
0
4
System.Data.dll
100665156
System.Data
0
c
MailClient.exe
100670295
MailClient
MailClient.Storage.Data.SQLite.DbRepository1</type><br> <name>FindByOids</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Collections.Generic.IList
1[[System.UInt64, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]]
oids
15a
2b4
MailClient.exe
100670294
MailClient
MailClient.Storage.Data.SQLite.DbRepository1</type><br> <name>FindByOid</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.UInt64</type><br> <name>oid</name><br> </parameter><br> </parameters><br> </method><br> <offset>0</offset><br> <nativeoffset>33</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100680540</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.Storage.Application.Security.SecurityProfileCollection</type><br> <name>FindSecurityProfileByOid</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.UInt64</type><br> <name>oid</name><br> </parameter><br> </parameters><br> </method><br> <offset>0</offset><br> <nativeoffset>13</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100687044</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.Accounts.Db.MailAccountConfiguration</type><br> <name>get_SecurityProfile</name><br> <parameters></parameters><br> </method><br> <offset>0</offset><br> <nativeoffset>3a</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100693543</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.UI.Forms.formSendMail</type><br> <name>get_securityProfile</name><br> <parameters></parameters><br> </method><br> <offset>14</offset><br> <nativeoffset>37</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100693461</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.UI.Forms.formSendMail</type><br> <name>.ctor</name><br> <parameters><br> <parameter><br> <assembly>MailClient.Mail</assembly><br> <type>MailClient.Mail.IMail</type><br> <name>mail</name><br> </parameter><br> <parameter><br> <assembly>MailClient</assembly><br> <type>MailClient.UI.Forms.formSendMail+SendResponseType</type><br> <name>sendResponseType</name><br> </parameter><br> <parameter><br> <assembly>MailClient</assembly><br> <type>MailClient.Accounts.MailAccount</type><br> <name>mailAccount</name><br> </parameter><br> </parameters><br> </method><br> <offset>542</offset><br> <nativeoffset>c73</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100693473</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.UI.Forms.formSendMail</type><br> <name>createNew</name><br> <parameters><br> <parameter><br> <assembly>MailClient</assembly><br> <type>MailClient.Accounts.MailAccount</type><br> <name>mailAccount</name><br> </parameter><br> </parameters><br> </method><br> <offset>0</offset><br> <nativeoffset>1e</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100693481</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.UI.Forms.formSendMail</type><br> <name>CreateNew</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.String</type><br> <name>mailTo</name><br> </parameter><br> <parameter><br> <assembly>MailClient</assembly><br> <type>MailClient.Accounts.MailAccount</type><br> <name>mailAccount</name><br> </parameter><br> </parameters><br> </method><br> <offset>0</offset><br> <nativeoffset>1f</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100693153</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.UI.Forms.formMain</type><br> <name>ShowNewMessage</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.String</type><br> <name>mailto</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Boolean</type><br> <name>useDefaultAccount</name><br> </parameter><br> </parameters><br> </method><br> <offset>56</offset><br> <nativeoffset>a6</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100693345</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.UI.Forms.formMain</type><br> <name>menuItem_Actions_NewItem_Click</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Object</type><br> <name>sender</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.EventArgs</type><br> <name>e</name><br> </parameter><br> </parameters><br> </method><br> <offset>20</offset><br> <nativeoffset>26</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100667402</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ToolStripItem</type><br> <name>RaiseEvent</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Object</type><br> <name>key</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.EventArgs</type><br> <name>e</name><br> </parameter><br> </parameters><br> </method><br> <offset>0</offset><br> <nativeoffset>52</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100677264</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ToolStripMenuItem</type><br> <name>OnClick</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.EventArgs</type><br> <name>e</name><br> </parameter><br> </parameters><br> </method><br> <offset>17</offset><br> <nativeoffset>45</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100667386</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ToolStripItem</type><br> <name>HandleClick</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.EventArgs</type><br> <name>e</name><br> </parameter><br> </parameters><br> </method><br> <offset>3b</offset><br> <nativeoffset>92</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100667378</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ToolStripItem</type><br> <name>FireEventInteractive</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.EventArgs</type><br> <name>e</name><br> </parameter><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ToolStripItemEventType</type><br> <name>met</name><br> </parameter><br> </parameters><br> </method><br> <offset>62</offset><br> <nativeoffset>aa</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100667377</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ToolStripItem</type><br> <name>FireEvent</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.EventArgs</type><br> <name>e</name><br> </parameter><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ToolStripItemEventType</type><br> <name>met</name><br> </parameter><br> </parameters><br> </method><br> <offset>cb</offset><br> <nativeoffset>8d3da8</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100677276</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ToolStripMenuItem</type><br> <name>ProcessCmdKey</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Message&</type><br> <name>m</name><br> </parameter><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Keys</type><br> <name>keyData</name><br> </parameter><br> </parameters><br> </method><br> <offset>19</offset><br> <nativeoffset>46</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100681238</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ToolStripManager</type><br> <name>ProcessShortcut</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Message&</type><br> <name>m</name><br> </parameter><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Keys</type><br> <name>shortcut</name><br> </parameter><br> </parameters><br> </method><br> <offset>1c3</offset><br> <nativeoffset>2e8</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100681237</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ToolStripManager</type><br> <name>ProcessCmdKey</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Message&</type><br> <name>m</name><br> </parameter><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Keys</type><br> <name>keyData</name><br> </parameter><br> </parameters><br> </method><br> <offset>8</offset><br> <nativeoffset>2c</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100666063</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ContainerControl</type><br> <name>ProcessCmdKey</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Message&</type><br> <name>msg</name><br> </parameter><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Keys</type><br> <name>keyData</name><br> </parameter><br> </parameters><br> </method><br> <offset>c</offset><br> <nativeoffset>3b</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100674913</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Form</type><br> <name>ProcessCmdKey</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Message&</type><br> <name>msg</name><br> </parameter><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Keys</type><br> <name>keyData</name><br> </parameter><br> </parameters><br> </method><br> <offset>0</offset><br> <nativeoffset>28</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100693281</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.UI.Forms.formMain</type><br> <name>ProcessCmdKey</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Message&</type><br> <name>msg</name><br> </parameter><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Keys</type><br> <name>keyData</name><br> </parameter><br> </parameters><br> </method><br> <offset>bc</offset><br> <nativeoffset>129</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100665389</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Control</type><br> <name>ProcessCmdKey</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Message&</type><br> <name>msg</name><br> </parameter><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Keys</type><br> <name>keyData</name><br> </parameter><br> </parameters><br> </method><br> <offset>2e</offset><br> <nativeoffset>92</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100665389</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Control</type><br> <name>ProcessCmdKey</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Message&</type><br> <name>msg</name><br> </parameter><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Keys</type><br> <name>keyData</name><br> </parameter><br> </parameters><br> </method><br> <offset>2e</offset><br> <nativeoffset>92</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100666063</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ContainerControl</type><br> <name>ProcessCmdKey</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Message&</type><br> <name>msg</name><br> </parameter><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Keys</type><br> <name>keyData</name><br> </parameter><br> </parameters><br> </method><br> <offset>0</offset><br> <nativeoffset>14</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100665389</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Control</type><br> <name>ProcessCmdKey</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Message&</type><br> <name>msg</name><br> </parameter><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Keys</type><br> <name>keyData</name><br> </parameter><br> </parameters><br> </method><br> <offset>2e</offset><br> <nativeoffset>92</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100665389</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Control</type><br> <name>ProcessCmdKey</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Message&</type><br> <name>msg</name><br> </parameter><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Keys</type><br> <name>keyData</name><br> </parameter><br> </parameters><br> </method><br> <offset>2e</offset><br> <nativeoffset>92</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100665389</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Control</type><br> <name>ProcessCmdKey</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Message&</type><br> <name>msg</name><br> </parameter><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Keys</type><br> <name>keyData</name><br> </parameter><br> </parameters><br> </method><br> <offset>2e</offset><br> <nativeoffset>92</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100666063</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ContainerControl</type><br> <name>ProcessCmdKey</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Message&</type><br> <name>msg</name><br> </parameter><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Keys</type><br> <name>keyData</name><br> </parameter><br> </parameters><br> </method><br> <offset>0</offset><br> <nativeoffset>14</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100672510</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.UI.Controls.controlItemList
2
ProcessCmdKey
msg
keyData
20
5d
&n
