Also, for anybody who wants to modify themes and aren’t particularly artistic, I found the following website extremely helpful to find colors that are in the same shade but different tints. This is the particular color family that I used for Pink Frost: http://www.color-hex.com/color/e74edb
Hi ajvincelli, that’s awesome to hear! I’m glad you were able to adapt it. Great link as well.
I tried to PM you on here, but it seems that there’s no option. Rather than give out my e-mail address on this public forum, is it possible that you can follow me on Twitter (@scar45) or Google+ (https://plus.google.com/u/0/112132608…) so that we can get you to send me the file via private messaging on one of those networks?
Afterwards, I have no problem putting it on my web server to host it for you.
Hope that sounds good
thank you for this useful link.
regards
Jan
Pink Frost by ajvincelli!
All credit for the modifications to my original Dark Frost theme (above) go to ajvincelli who has created a ‘warmer’ theme for anyone out there who enjoys pink.
Download: http://scar45.me/file_download/3/Pink_Frost.emtheme
Thanks George!!!
This is nice Theme, but one user found problem with contacts, when you click in left bar on contacts, then double click on contact and you want to switch its folder then it is unreadable…
otherwise I like this theme, but this could make problems to some users/customers.
regards
Jan
Thanks for passing this along, Jan. I can’t seem to replicate the problem… I see where the user is indicating (the folder to switch), but mine looks fine. If anybody else can replicate the problem, please post a screenshot! I’m on eM Client version 5.0. Also, let me know if the user experiences this with the Dark Frost theme… there should be no difference between them at this particular graphic.
Another user is pointing out another error with this theme - bad menu visibility.
Anyway if anyone see any problem with 3rd party theme please put it right here as we do not provide support for them.
regards
Jan
Awesome job George!
Thanks for the screenshot! I believe I was able to tweak the settings. Stand by for the url to the new Pink Frost theme (v1.1). Thanks again, and sorry for the inconvenience!
thank you for taking care about your creation
when you will release update version can you please post it into this topic?
https://discourse.emclient.com/emclient/to…
it should server as topic only for templates
best regards
Jan
Okay, the new file (Pink Frost v1.1 is uploaded and has the same link that the old one did. Check out this link to download: https://discourse.emclient.com/emclient/to…
sweet, that you very much
Is there any way to change a theme so there’s so difference (color, border, rule, etc.) between the edges of the mail tree view, Smart Folders and the view picker (calendar, contacts, etc.). I know I can make the view pickers into buttons but there doesn’t seem to be a way to even draw a horizontal border between the main view and the Smart Folders. I find this to be very confusing visually since these are separate widgets with separate scrollable regions. There should be an option to draw a horizontal border between the main mail view and the smart folders.
Hi, could you make screenshot of place you have on your mind?
Jan
No, this is not possible to colourize.
Jan
