My wife and I have a shared domain name and use a provider for Exchange services. I recently added my wife’s calendars to eM Client. Today, I had reminders for two of her appointments and when I tried to dismiss them, either individually or Dismiss All, eM Client crashed. I have not had a crash on this action in the past, either for my Exchange calendars or my wife’s Google calendars.
What version of eM Client are you running.
Also do you have Windows or Mac & what OS version.
eM Client 10.0.3117 (493de5a)
Windows 11 Home 22H2
Ok try closing eM Client and download and install the latest release version 10.0.3125 from the release history page.
https://www.emclient.com/release-history
If still the same problem, try uninstalling eM Client and “don’t delete the database” when asked on the uninstall wizard and then reinstall.
Lastly if still the same issue, could possibly be an OS issue and might need patching. Win 11 build 23H2 was released a while ago. Check your Windows update and install that if available.
Are you able to reproduce it? So does dismissing another reminder also crash eM Client?
Update:
I had to wait until I was getting reminders again after fixing the well-known “internal server error” caused by the way eM Client handles some attachments.
If I get a single reminder and click Dismiss All or select it and click Dismiss, the dialogue closes but re-appears with the reminder still there.
If I get a single reminder and close the dialogue, it goes away and doesn’t reappear until…
… If I get more than one reminder and click Dismiss All, eM Client crashes. When I re-open it, several calendars have become deselected. Not sure yet if these are the same each time.
… If I get more than one reminder and dismiss just one - I just had one reminder on my calendar and one on my wife’s. I dismissed mine and eM Client crashed. This has not happened if all the reminders are for me.
If it’s still happening with the latest eM Client, I would then suggest to test if it’s a possible corruption in the local database somewhere.
To do that, close eM Client and rename the hidden database to eg: eM Client-Old and then reopen eM Client and setup as new.
In 10.0.3447, I can dismiss reminders in my own calendar, but not those from my wife’s - even if they originated in an invitation from me.
On the plus side, it’s no longer crashing when I dismiss reminders. So far!
Tracked down the reason for not being able to dismiss reminders for my wife’s account - I can’t turn off the “Show reminders” setting as I only have read access to the account on the server. Would be nice if there was some way that eM Client could override that.
Go to the calendar section of eM Client. Right-click on that folder and choose Properties. Untick the option to show reminders.
OK, that’s weird. I did that before and got a message that the change couldn’t be made because I only have read access to the folder, as in my previous post. But now the setting is showing as cleared. Huh.
On the downside, I got a crash (immediate close, no error dialogue) when I clicked Dismiss All on a notification that showed two reminders from my wife’s account.
Bumping this. The crash on dismissing reminders still happens. 10.0.3530.0
I bit the bullet and deleted the database yesterday as @cyberzork suggested and that seems to have sorted it - so far.
I did back up all accounts and settings before I deleted the database. One thing I noticed that doesn’t seem to get saved is the Favorites. Did I miss something?
Favourites are saved when you normally do a Backup and Restore.
Bumping this as the issue has raised its ugly head again. Some additional information:
- To be clear, it only happens on other people’s calendars to which I have read but not write access
- If I try to dismiss a single reminder, that action gets ignored and the reminder remains in the list
- If I click “Dismiss All” when I have such reminders, eM Client crashes
- If I go to the Properties for the calendars in question and uncheck “Show Reminders”, the checkbox clears (and shows clear when I next look), but I get a message that I don’t have Write access to the folder. Oddly, if I set then clear that checkbox I do not get the message, even if I close and restart eM Client between setting it and clearing it.
