Crashes and closes eM Client
Im using Version 7.2.37472 and after some time using it without problems, the error field comes on, asking to transmit the error message.
I cannot transmit the error to eM client and have to shotdown the client with the task manager.
Uninstall that version of eM Client as it was not ready to be released when it was mistakenly published. Then download the latest version available in the Release History and see if the problem persists.
During the uninstall you will be asked if you want to delete the database directory. Select NOT to delete it and all your data and settings will be there after the downgraded install.
Hi Gary,
great! It worked exactly as you said.
Thank you very much,
George
