We have our own caldav server to store our family memebers’ calendars. A few days ago if I try to turn on my father’s calendar, emC crashes. It doesn’t happen with any of the other calendars. I tried to do a repair on this calendar, but then it crashes immediately. The strangest thing is that I’ve set up my account on another computer, and there I can access my father’s calendar without any trouble. Tried to remove my caldav account and set it up again, the problem persists.
Any idea on how to solve this issue?
Thanks,
Balazs
The error message is the following:
eM Client (7.0.26687.0) Windows: Microsoft Windows NT 10.0.14393.0, Framework: 4.0.30319.42000 The following error has occurred: System.ArgumentNullException: Az érték nem lehet NULL. Paraméter neve: attendeeAddress a következő helyen: MailClient.Schedule.Attendee.Attendee..ctor(String displayName, Uri attendeeAddress, AttendeeType type, AttendeeRole role, AttendeePartStatus partStatus, Boolean rsvp, Uri[] delegatedTo, Uri[] delegatedFrom, Uri sentBy, Int32 lastSequence, DateTime lastDtStamp, String scheduleStatus, ScheduleAgent scheduleAgent) a következő helyen: MailClient.Storage.Schedule.Data.DbScheduleRepository.LoadAttendees(UInt64 parentId) a következő helyen: MailClient.Storage.Schedule.Data.DbScheduleRepository.Load(IDataReader reader) a következő helyen: MailClient.Storage.Data.DbRepository`1.FindByOids(IList`1 oids) a következő helyen: MailClient.Storage.Data.DbRepository`1.FindEnumerable.<getenumerator>d__8.MoveNext()
a következő helyen: MailClient.Storage.Application.ItemCollection`2.<getenumerator>d__53.MoveNext()
a következő helyen: MailClient.Storage.Application.Schedule.ScheduleItemCollection`1.GetItemList(QueryDefinition customQuery)
a következő helyen: MailClient.Storage.Application.Schedule.ScheduleItemCollection`1.GetEnumerator()
a következő helyen: MailClient.Storage.Views.ItemCollectionView`2..ctor(Folder folder, ItemCollection`2 itemCollection, IUIDispatcher dispatcher, CancellationToken cancellationToken, SortField[] sortFields)
a következő helyen: MailClient.Storage.Application.Folder.CreateEventViewInternal(IUIDispatcher dispatcher, CancellationToken cancellationToken, TimeInterval[] boundaries, SortField[] sortFields)
a következő helyen: MailClient.Storage.Application.Folder.CreateEventView(IUIDispatcher dispatcher, CancellationToken cancellationToken, TimeInterval[] boundaries, SortField[] sortFields)
a következő helyen: MailClient.Storage.Application.AggregatedViewProvider.CreateEventView(IUIDispatcher dispatcher, CancellationToken cancellationToken, TimeInterval[] timeInterval, SortField[] sortFields)
a következő helyen: MailClient.UI.Controls.controlCalendar.UpdateFolderQuery(CalendarView view, Boolean useBeginUpdate)
a következő helyen: MailClient.UI.Controls.controlCalendar.set_Folder(IViewProvider value)
a következő helyen: MailClient.UI.Forms.formMain.ActivateEventView()
a következő helyen: MailClient.UI.Forms.formMain.controlEventFolders_FolderCheck(Object sender, FolderChangeEventArgs e)
a következő helyen: MailClient.UI.Controls.controlFolders.OnFolderCheck(FolderChangeEventArgs args)
a következő helyen: MailClient.UI.Controls.controlFolders.treeView_NodeCheckedChanged(Object sender, TreeNodeEventArgs e)
a következő helyen: MailClient.UI.Controls.ControlTreeView.ControlTreeView.OnNodeCheckedChanged(TreeNodeEventArgs e)
a következő helyen: MailClient.UI.Controls.ControlTreeView.ControlTreeView.NodePropertyChanged(TreeNode node, String property)
a következő helyen: MailClient.UI.Controls.ControlTreeView.TreeNode.ReportPropertyChanged(String property)
a következő helyen: MailClient.UI.Controls.ControlTreeView.TreeNode.set_Checked(Boolean value)
a következő helyen: MailClient.UI.Controls.ControlTreeView.ControlTreeView.OnMouseDown(MouseEventArgs e)
a következő helyen: System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
a következő helyen: System.Windows.Forms.Control.WndProc(Message& m)
a következő helyen: System.Windows.Forms.ScrollableControl.WndProc(Message& m)
a következő helyen: System.Windows.Forms.ContainerControl.WndProc(Message& m)
a következő helyen: System.Windows.Forms.UserControl.WndProc(Message& m)
a következő helyen: MailClient.UI.Controls.ControlTreeView.ControlTreeView.WndProc(Message& m)
a következő helyen: System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
a következő helyen: System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
a következő helyen: System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
a következő helyen: System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
a következő helyen: System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
a következő helyen: System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
a következő helyen: System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
a következő helyen: MailClient.Program.<>c.<main>b__62_1()
a következő helyen: MailClient.ExceptionUtils.ExceptionUtils.Filter(BodyDelegate body, FilterDelegate filter, Action`1 handler)<span> </span></main></getenumerator></getenumerator>
