eMclient can’t copy things from the jabber history. ctrl - c and contextmenu (which not exist) doesnt work. i try to switch to another solution. to many problems and not much updates.
Hi Stefan, what version of eM Client are you currently using? Can you copy and paste text in other sections of the application? Can you please check if you have the latest available version of eM client installed on your computer?
I’m currently use 6.0.21034.0. Text from the chat window i can copy, not very well, but it’s ok, but from the history window i can not copy anything. My current Workaround is to select the text and move them with mouse outside the window, but its very annoying. Another question: Why are not jabber groups working?
Hi again, what do you mean by “not very well”, how are you copying your text regularly? Just select the text and use the ctrl+c/ctrl+v shortcut, or right click the text and select copy.
What do you mean by jabber groups, groups for sorting or group chat? Group chat is not a supported feature in eM Client.
To the first subject. Text which is copied is often wrong formatted, but its not my main problem. The main problem for me is, that ctrl+c/v and right click doesn’t work in the history window.
With jabber groups i mean group chat yes. It is possible to create groups, but they are not supported. I can see http://take.ms/oAhu9 the chat rooms under IM services, but can’t join them.
Hi again, you’re right you can not copy and paste in the communication history window, I’ll report this issue to the developers for more information about a possible solution. If you’re having issues with formatting while copying, can you make a screenshot of the issue, I’ll be happy to take a look at the issue.
As to the chat room issue, as I previously stated chat rooms are not supported in eM Client, the list is able to show a number of available services however not all are supported.
Thank you for understanding,
