Is Copperplate Gothic unavailable in eM Client?
eM Client uses your Windows/Mac fonts, so it depends what you have installed in your OS.
I did not have Copperplate Gothic installed so I downloaded it. After restarting eM Client it is there.
It may be that the font version you have is unusual. Try removing it from your OS and download from another source. Fonts Geek is a good source for reliable free fonts. http://fontsgeek.com/fonts/Copperplate-Gothic-Bold-Regular
THIS ERROR
How is that relevant to the font issue?
YES I CANT BE DOWNLOAD A MESSAGES AND IMAGES AND LINKS
Follow the link I gave above for downloading the font. It will be done in your web browser, not eM Client.
Thanks for the reply, Gary. However, I tried what you suggested and no result. So, I figured I would ask for a more detailed reply. I went to the source you gave, downloaded the font, sent it to my OS and re-started eM. It didn’t work. Can you be a bit more precise on the steps? Where exactly did you send the downloaded font on your computer?
Download the zip file and extract it to C:\Windows\Fonts.
The fonts will now be available in eM Client.
Thank you much. It worked.
