In the last month I have been making my conversion from 2003 Outlook to eM Client. I am enjoying using eM Client and in some ways have found it better then Outlook. I have used Outlook for so long it was easy and quick for me to use. Thankfully, eM client is close enough to Outlook that the learning curve is flat and easy. Thanks, SteveG
thank you, we’re glad that you’re satisfied with the application
and hopefully it’ll stay that way.
