eM client continuously looses connection to IMAP server, settings are correct. I will get an error message, cannot connect to server. Go to accounts, settings diagnostics and everything checks ok. Then it will start working again. Very troubling, any ideas would be appreciated.
IMAP and SMTP settings below and as suggested except SMTP is port 587. I have tried creating a special inbound firewall rule for em client to see if that helps. My problem is intermittent throughout the day and when I notice no emails coming in I go to diagnostics in em client and after they check ok mails will eventually start coming through again?
Ah! eM Client is not compatible with Charter servers. They use a non-standard form of IMAP that requires the client to fetch messages on a schedule. eM Client uses IDLE IMAP, which means it waits for the server to send notification of changes to the inbox. So they both just sit there waiting for the other to make the first move.
eM Client will sync with the sever when you first start the application, and when you run diagnostics, but otherwise it is unlikely.
BTW, the correct security policy for SMTP port 587 is Force usage of SSL/TLS, but that is for sending so will not make any difference to the incoming messages.
