I’m wondering if anyone has familiarity with Cardscan (Executive version 8.0.5) and, if so, has found a way to synchronize their Cardscan database with EM Client’s contact database (version 5.0.18661.0). The Cardscan software has a menu of supported email clients for synchronization and I’m wondering if choosing one of them has worked for others. I’m a little reluctant to try it blind as I don’t want to corrupt either database by mistake.
I personally do not have any experience with it, but if you want to experiment I suggest you using in eM Client - File - Backup… to backup your database, then you will have possibility to revert any disaster without problem.
Jan
Thanks for your suggestion, John.
you’re welcome
Jan
