what is the point of the contacts panel i cannot get anything to show in it - there are a couple of solutions put forward in other posts - neither work - i have a contact list with entries but they do not show in the panel
so simple questions - does the panel work for anybody - if so how do you get contacts to show
i have looked at all settings - am i missing the obvious
does it - well it does not for me or i dont understand you - in simple terms
i have an email open from a contact i have in my contacts list - that email is a history of various emails from the contact - what should i see in the contact panel - for me its blank
Here I have your message from the forum opened. It is received from forum@emclient, so all previous messages from that address will be displayed in the history.
ok thanks - whatever email i open i dont see anything in the contacts panel - maybe a setting - not a disaster its not what i thought - my assumption is it would show a list of my saved contacts for easier access
that said i dont know why i just see a blank panel
Do you see the settings cog next to Contacts Details at the top of the bar?
Click on that, then make sure you have chosen what you want to be displayed. Also, click on Choose Folders and make sure that all the folders where these messages are, are also ticked. I just have all folders selected.
i have settings cog and afaik i have ethings set up correctly - the next bit you say - ‘choose folder’ where is that i i dont know what you mean - i can see nothing saying that
