Hi, I use EM-Client as a standard e-mail and contact manager and I have a lot of contacts. More than 1000.
So I need to export all my contacts in to an excel spreadsheet in XML or XMLS format in order to:
* Organize the existing contacts
* Delete duplicated contacts
* Complete empty fields
* Include more 1500 new contacts on list
And after all, after make them organized as I will, I need to import them again to Em-Client contact list.
The big problem is that the only option I found is to export to excel as a VCF file, but it’s not so easy to edit as an excel spreadsheet.
I need to do this operation because it ́s impossible to edit and add one by one, once I have more than a thousand contacts.
Hope that you can understand my needs and help me soon as its possible.
Just a thought from a eM Client user… Have you tried to find a converter application online by doing a search for something like “convert vcf to excel XML”? For example, I found this application at Cnet.com’s download site:
Hi Olivia, I dont understand why you didn’t fix this function because it could be usefull for many eM-Client users.
I did not found any conversor and Im still without can update my contacts.
Please, can you indicate some method I can use to change mass contacts?
In Thunderbird, ignore the new account nags, go Address Book > Tools > Import > Contacts then import your VCF file
Make necessary changes
Then you can Export the addresses in Thunderbird to a CSV file and import to eM Client, alternatively in eM Client import direct from Thunderbird.
