After downloading EM Client, I tranfered my contact list over from Thunderbird succesfully. I then added new contacts and a couple days later they all disappeared. When I go to write an email and type in the first letter of a name, the contact shows up in the to: line. When I click on the contacts tab on the left side pane it says I have no contacts. Any help would be appreciated.
Hi Scott,
When you click on the Contacts tab, do you see an email account or Local Folders Contacts
in the tab?
Tick the box and they will show…
By default they’re imported into local folders, if you don’t see local folders under contacts, go to Menu > Tools > Settings > General and check the “Show Local Folders” option.
Peter.
