I imported my contacts from Thunderbird but they do not appear under “contacts”. How do I find the imported list?
Hi, during the import you should be able to select the folder to which they were imported to.
I believe that by default they’re imported into local folders, if you don’t see local folders under contacts,
go to Tools > Settings > General and check the “Show Local Folders” option.
Thanks. You are correct.I had my setting set to not show local folders. I appreciate the help.
Great! Glad this worked. If you have any other issues or questions about the application, let us know, we’ll be happy to help.
