Hello, I have several WEB.DE accounts set up in eM Client, but I’m having trouble with one of them. I keep getting the message: “Please enter the username and password for …@web.de.” The username and password are correct, and I can send and receive emails using the account. Deleting and setting up the account again hasn’t helped either. The diagnostic test says everything is OK. What could be causing this issue?
Hi @t.hoffmann,
Thanks for the clear description. Since sending and receiving work, we need to find out which connection of this account keeps asking for the password. Could you please send us:
- Your eM Client version (Menu > Help > About) and your Windows or macOS version.
- When exactly the prompt appears (at startup, every few minutes, when sending…) and whether Menu > Operations… shows an error for this account at that time (the exact error text helps).
- Which services are ticked for this account in Menu > Accounts… > [the web.de account] > General > Services (for example IMAP or POP3, SMTP, CalDAV / CardDAV).
- Logs:
- Go to Menu > Settings > Advanced > Logging and click Clear Logs.
- Under this account, tick IMAP (or POP3), SMTP and CalDAV / CardDAV if they are listed. Under the global modules, tick Authentication.
- Save and restart eM Client.
- Wait until the prompt appears and note the time.
- Send the logs with the send button in the same Logging section, and put the link to this topic in the description, so we can find them.
- Untick the modules again afterwards.
The menu paths above are from the Windows version. Please don’t post logs, passwords or screenshots with personal data here in the topic.
eM Client Team
