Connection failed to gmail after upgrade to 10.0.3530 (f0b89b7)
After I upgraded to this version there has been a steady occurrence of connection errors from my main google account. After I upgraded, it asked me to go through the oauth authentication with a couple of the email accounts. I did that. And then I started receiving these errors. I’ve never had them before. The error is:
“Main: Connecting to Main failed
[SMTP] An atempt to connect to Main failed. This could be caused by temporary server unavailability or incorrect settings. Do you want to check the settings?”
I’m still able to receive and send email, so perhaps these are errors that previously were silently ignored by emclient? Or is it related to a new way of authenticating? This version though is quite insistent on showing me them and for me to explicitly mark them as “Ignored” or for me to check the settings, which is quite annoying because things seem to function fine.
Log snippet:
16:32:34 Main [SMTP] MailClient.Accounts.ConnectionException: Connection failed due to the following reason:
"{“status”:“invalid_request”,“scope”:"https://mail.google.com/“}”
—> MailClient.Authentication.SaslException: {“status”:“invalid_request”,“scope”:“https://mail.google.com/”}
at MailClient.Authentication.Mechanisms.OAuthBearerMechanism.Client.EvaluateChallenge(Byte challenge)
at MailClient.Protocols.Smtp.SmtpSendCommand.Authenticate(WorkerStatus status)
at MailClient.Protocols.Smtp.SmtpSendCommand.Connect(WorkerStatus status)
— End of inner exception stack trace —
at MailClient.Protocols.Smtp.SmtpSendCommand.Execute(WorkerStatus status)
at MailClient.Accounts.AccountManager.SendAsync(IAccount account, CancellationToken cancellationToken)
at MailClient.Reminders.ReminderManager.TimerSendLaterTrigger(Object sender, ElapsedEventArgs e)
Maybe suggest to try closing eM Client and then go to your Google Myaccount connections (Third Party apps section) and try removing eM Client, and then reopen eM Client and allow eM Client access again.
Google - Third-party apps and services connections page.
https://myaccount.google.com/connections
Apart from that, suggest next to go to “Menu / Accounts” and try removing and re-adding your Gmail account via the automatic account wizard at the top.
Note:- If you do try removing and re-adding your Gmail account, make a manual backup first via “Menu / Backup” incase you need to restore for any reason. You can see when the backup is complete in Show Operations via the dropdown on the right of Refresh.
Lastly sometimes background resident programs can cause interference like eg: Optionally installed Firewall / Security programs, or Optionally installed Antivirus programs or VPN’s. So if you have anything like that installed “other than what comes default with your OS”, try completely disabling those to test to see if that makes any differance.
@hktegner have you solved the problem? If so, how? I have the identical problem, interestingly only for one gmail account, the rest works fine. Also a problem since version 10.
Curiously the errors seem to have gone away now, so perhaps it was an intermittent problem with the gmail service.
