Command-minus not working
When displaying a message (on MacOS), command-plus increases the font size, but command-minus also increases it.
Hi Bernard, in your trustpilot review you mentioned this happens with a French keyboard, can you please see/try what happens when you use CTRL and these 2 keys? Theoretically, the ) in French setup should be the minus - and the minus - should be the plus +.
(since these are - and + in the ENG keyboard)
