What happened to column configuration that became so dull in version 7 ?
Hello Yishay,
some columns options are not available with the Conversation view enabled.
Is there any special column that you are missing? What do you mean by the current configuration being dull?
I agree with Yishay.
When I try to add any new column to the “Select Contact” window, nothing happens! The default columns (Full Name, File As and Email) are the only ones that stick, any other are ignored.
