Just reporting this for bug feedback, since the most recent update (7.2.34062.0), many times when I click on the taskbar icon to bring EMclient up, I instead hear my generic alert tone, then second click shows EMclient. Not other messages or issues reported, seems to be a focus issue.
I also see the same issue. It seems to occur when a new message arrives while the program is minimized. I am a pro user, so I will submit a ticket.
eM Client support responded by saying they are aware of the problem and will try to fix it as soon as possible.
Well, nearly a year later, I am finding this happens to me several times a day. EMclient is not focused or behind other windows. A click to the taskbar icon gives a alert tone, but does nothing. Second click to it brings it up. It then works ok for a little while. Pretty annoying, it would be great to hear this has moved up on the list of items.
Still seeing this as well even after a new pc build… Will it ever get fixed, its very annoying.
Are you using v8? It doesn’t seem to be a problem in new version.
Had no idea the beta was out, thanks!!
