Checking database after each system shutdown
Often when I reboot Windows 11, my eM Client says it was not shutdown correctly and takes a long time to check the database. Hopefully this can be fixed - with an orderly system shutdown eM Client software should exit or make sure the database is OK, not require the user to manually exit the email software before shutting down or rebooting the system.
