I want to change from Pop3 to Imap. Is there any way to move my emails from my local computer back to the email server ? I do have regular backups.
Hi, you will have to remove and add your account again. You can use File - Export… and then File - Import or drag and drop to get your emails back.
Jan
Thanks very much. It worked great.
How exactly did you do that?
