I want to import and use a different sound for incoming email notification. Please let me know if this is possible and how to do it…thanks
Hello Wizard,
Yes, it is possible. Go to eM Client’s system folder (C:\Program Files\eM Client\Sound) and replace the new_mail.wav with another .wav file that you’d like to use.
Maurice
I did exactly that! I was about to post this suggestion, and you beat me to it. I used a simple POP sound (WAV file). I can attach here if there is a way.
