we want to use exchange for public folders.
how could we use the same categories for each user?
how is it possible to edit the categories with an offline editor?
thanks for your help
As far as I know the IceWarp Desktop Client (rebranded eM Client that works with the IceWarp server) is the only version that allows syncing of tags (previously called categories).
You can export tags using Menu > File > Export > Export settings to xml, then select tags. That will create an editable file with just the tag details and can later be imported to other installations of eM Client.
