I cannot send emails - only receive them. Changing SMTP settings does not help. It says there are issues with the account under diagnostics, and then it fixes one but not SMTP. After clicking “fix” I get the test email but then it doesn’t work again.
Hi, could you tell me your email account provider and your SMTP settings in Tools - accounts - your accunt - SMTP.
I am looking for port and security policy.
Jan
Port 465 - use SSL/TLS on special port
It also didn’t work on force usage of SSL/TLS
Try:
port: 25
security policy: Use SSL/TLS if available
port: 587
security policy: Force usage of SSL/TLS
