I have a hotmail account and an icloud account. Icloud works fine. Hotmail receives ok but when I reply to a message or try to send a new message eMC has started picking the icloud account to send from by default and when I try to use hotmail I get the following error message and will not send.
[SMTP] Cannot send message (Sending email “test” failed with error: ‘From’ field address not accepted due to the following reason:
"5.7.0 From address is not one of your addresses
First off for privacy reasons suggest to remove the first part of your email address in your post above.
For this issue, I would suggest to try removing and re-adding your Hotmail account via the automatic email wizard setup via “Menu / Accounts”.
Then set whichever account you want as the default and save accounts. Then close and reopen eM Client.
Note: Before removing your Hotmail account, backup first via “Menu / Backup” (PC) or “File / Backup” (Mac). You can see when the backup is complete via the dropdown next to refresh.
