Cannot drag and drop any attachments when compiling a message. I have to use the attachment icons and browse to the attachment. When dragging an attachment the cursor change to No Go.
Using 7.0.30068.0 on Win10 64.
I have the same environment and have no problems (sane emclient and windows version)
There are a number of items on the web regarding this issue in windows explorer
Try re booting
Take a look at web search for the issue.
I used the search value of " drag and drop not working windows 10"
I do not know if any of this info is correct or not but take a look BUT Be Careful
Thanks Richard. Unfortunately my situation does not extend outside of eM and drag&drop work fine in all other applications, including my outlook client.
Try going to Program and Features (windows) and right click EmClient and select REPAIR
Bingo. Thanks Richard that worked.
