shows pop3 failure and will not connect to my e-mail server
Send us your POP3 logs please. Go to menu Tools->Settings->Advanced->Logging and check “POP3” under the problematic account. Then restart eM Client, try to simulate the issue and send us (with reference to this topic) the logs using the same logging settings window. Thank you.
