Hi there, copying and pasting events and appointments in eM Client is a mess.
environment: iOS 10.15.7., eM Client 9.2.2307
if you want to “copy” and “paste” (keys) an event in the calendar, eM Client has to be restarted before. If not, and you try to copy’n’past during your workflow, it won’t work. Very useful
If you copy events with “drag’n’drop” with pressed key (alt) you can easily copy and duplicate events and drag the copied event to another day. Thanks eM Client programmers for the gift. But anyway somehow it happened unrecognised and even more frustrating that these duplicate events “re-ajust” to their original date, so that you have a duplication of an event, but the duplication isn’t suddenly not anymore dragged at the new date, where it shoud be, but back at its duplicated date (then there are two same event entries - most sensless) It’s a bug, I know, but for reliability it is the most unreliable feature, which shouldn’t be bugged.
What do you think? Anyone same experienced?
