Connecting using a newly created fastmail account, the calendar does not appear even though I can see I have a fastmail calendar account in the em client as well as the standard imap account, any way to work out what is going on as there are no errors.
Typically if the account is setup with CalDAV, but the calendar folders do not appear in the Calendar section, then the CalDAV URI is incorrect. There will not be any errors.
Works in my phone ok
But based on what you said i have an idea
You were right, I had include too much in the URL, thanks for the tip
To setup Fastmail , Calendar and Contacts with eM Client, see the below link. Works the same with any of the latest versions of eM Client.
For the Fastmail Calendar, when you go to “Menu / Accounts” you click for adding the Calendar, “Add account” and click “Calendar” manually, and choose Caldav and follow the Fastmail Calendar setup instructions on the Fastmail URL Example above.
For the Fastmail Contacts, when you go to “Menu / Accounts” you click for adding the Contacts, “Add account” and click “Contacts” manually, and choose Carddav in eM Client and then follow the Fastmail Contacts setup instructions on the Fastmail URL Example above.
