When I installed eM client, I entered a whole year’s dates on the calendar and now, all of a sudden, they have disappeared along with the calendar ! There is no tab at the bottom left for the calendar either. Help !!!
You may have inadvertently hidden the calendar tab. To restore, right-click on any other tab and make sure that “Calendar” is checked. On the calendar page, make sure that on the calendar list pane, the calendars you want to display are checked.
Thanks for your reply. I have now got the calendar tab back at the bottom, but all there is to the right of the tabs is a message "This folder contains no items and no operation can be performed. I still can’t bring up the monthly calendar view and all the entries that I made.
Did you ever find a fix for this? Same thing happening to me.
Check toi make sure that the appropriate calendars are set to display. Particularly the local calendar.
Don’t know what happened but it just seemed to clear itself about 2 months ago and has been ok ever since.
