Calendar Notifications going
I’m using eMclient on Android 17.
I’ve set the reminder default to be 10 mins.
The calendar is in sync with an outlook calendar, but I’d like to use the eM program.
If I create a calendar event (in em) it sets the reminder to 10 mins and is shown as the :bell:symbol if I look in the agenda. It also syncs to outlook if I look there.
However, after a short time period the :bell: symbol clears from eM and the reminder alarm does not occur. However, it stays in outlook and that still gives the reminder.
So I create the event in eM, it syncs to outlook, but then appears to clear from eM but remains in outlook :man_shrugging:.
What’s happening?
Any help appreciated.
Thanks.
Edit - I’ve just found that if I create an event with a reminder, then look in Agenda the :bell:is there (as mentioned above). But if I press the ‘three dots’ menu and press refresh the :bell: vanishes at that point.
