Using the latest eM Client that was updated through autoupdate. Server is Kerio Connect 7.4.3. Using CalDAV protocol. Time zone is UTC+2 in Windows and set automatically update daylight savings time.
Event created with eM Client shows correct time in eM Client but on iPads and iPhones it’s an hour late. Events created on an iPad shows correct time in eM Client.
Hi, can you try downloading this version (http://www.emclient.com/dist/v6.0.20224/setup.msi) and right click your calendar folder and select Properties > Repair and click on the Repair button.
Let me know if this worked for you…
Thanks, that did the trick!
Great, glad that it works, let us know if you encounter any other issues with the application, or if you have any questions, we’ll be happy to help!
