I have added 6 calendar entries (via eM Client) to Google Calendar since upgrading to emClient 6.
All of them are out by an hour. See attached screenshot - the problematic entries are marked in red (only 3 of them - the other 3 were on a different day).
Both Google Calendar and my local machine are set to UTC+10 (Sydney).
Note that all (previously created) calendar entries are perfectly fine. I believe this has happened only since the eM Client 6 upgrade - I can’t find the same issue with any older calendar entries.
Jane…there is a version offering a fix for this. Received a link from John today by email. Seems to work, but I had to go through and adjust many of the appointments I made while it was faulty. I’m presuming that if you install the latest version from the download page, it will have this fix, but I can’t be sure.
you have to contact me on [email protected], join this topic’s link in the email’s subject. I will send you version scheduled to be next patch but not released yet (should be next week, but I cant confirm).
for the information of others - any events already created with the one hour glitch will still have to be edited to the correct time after this patch is applied - all events created hereafter seem to work fine
thanks for solving the problem, it was quite worrying there for a bit
I appreciate the speed with which yu responded to my email contact
yes, for users on southern hemisphere it has been solved. If you contact me on [email protected] I will send you updated version, or you can wait for next patch release.
I’m finding events in Google calendar are now appearing eM one hour earlier that set in Google (whether on my phone or by web). I’m in Sydney Australia, where it’s currently on Summer Time (1 hour difference) - could this be the problem?.
Hi, this issue was solved successfully months ago, you are most likely experiencing different kind of issue.
Could you go to tools - settings - advanced, check GData under your account, apply and restart eM Client.
Simulate steps that leads to your issue and after that use “send logs…” to [email protected] together with this topic’s URL in subject.
