I have just begun using eM Client, I’m very enthusiastic about it. I have been able to resolve most issues easily except for one:
After using the calendar for a minute or so, I get the following screen when clicking on one of the display options at the top. As you can see, the items are still “there” but I get an overlay that hides the whole calendar from sight.
Hello. This happens when the application crashes during “painting” the calendar control. In order to fix it, we will need some more info from you. I´m writing a personal messsage where I will try to help you with the issue.
Ah, now I remember. It was MS Money causing such paint issues in other applications. But this will be a different case, because it happens in calendar only
