Calendar description box no longer sizeable
In v11 beta the calendar event description box no longer sizeable, it has a fixed size and one must scroll up and down to read the description - THIS IS VERY ANNOYING. Is there any way to disable or revert this change?
This is a bug in one particular version of the beta. It is already solved and it should not happen in the final version of eM Client 11.
