Calendar column
There is a calendar column all the way on the right. it is minimized but I dont want it at all.
How do I eliminate that column?
Hi Jerry, If you mean you want to remove the calendar icon from the pane on the right hand of the window (to the right of the message display), you can right-click on the icons, choose Customize, and then Add or Remove the items as you desire.
If you mouse over the top of the pane, an arrow appears and you can hide/show the entire pane, as you prefer.
Similar things apply to the Navigation Panel on the left hand side (to the left of the folders list).
Hope that helps!
