Hi eM Community,
I just installed v7.0.26453.0 and everything is almost fine excepted that my “principal” calendar is not synchronised getting this error from log :
11:29:46 MailClient.Storage.Application.OperationException: Erreur de synchronisation du dossier CalDAV : System.ArgumentException: Kind property of dateTime is Utc but the sourceTimeZone does not equal TimeZoneInfo.Utc
The 3 others calendars are well synchronised, they are all four hosted on a Horde personal server.
Any help would be appreciated.
Running W10, eMC Client v7.0.26453.0, Horde 5.2.2 with Kronolith 4.2.2 on Debian Jessie.
Hello Etienne,
can you please set up CalDAV logging in Menu>Tools>Settings>Advanced?
Tehn when this issue happens again, please copy the FULL content of the Operations>Log window.
here you will find the log file for CalDAV : https://owncloud.gabaut.fr/index.php/s/Pu2KkyKenMVdIX2
And here is the full log window content :
13:13:34 État en ligne: changé en En ligne. Raison : NetworkAvailability
13:13:34 [email protected] [IMAP] Synchronisation des sous-dossiers: Pour le dossier [email protected]/
13:13:35 [email protected] [IMAP] Téléchargement d’une partie de message…
13:13:35 [email protected] [IMAP] Téléchargement d’une partie de message…: Terminé
13:13:35 [email protected] [IMAP] Synchronisation des sous-dossiers: Terminé
13:13:35 [email protected] [IMAP] Synchronisation des messages: Pour le dossier [email protected]/INBOX
13:13:35 [email protected] [IMAP] Synchronisation des messages: Terminé
13:13:36 DAV [email protected] [CalDAV / CardDAV] Synchronisation des sous-dossiers: Pour le dossier DAV [email protected]/0/
13:13:37 DAV [email protected] [CalDAV / CardDAV] Synchronisation des sous-dossiers: Terminé
13:13:37 DAV [email protected] [CalDAV / CardDAV] Synchronisation des sous-dossiers: Pour le dossier DAV [email protected]/1/
13:13:37 DAV [email protected] [CalDAV / CardDAV] Synchronisation des sous-dossiers: Pour le dossier DAV [email protected]/0/outbox/
13:13:38 DAV [email protected] [CalDAV / CardDAV] Synchronisation des sous-dossiers: Terminé
13:13:43 DAV [email protected] [CalDAV / CardDAV] Synchronisation des éléments: Pour le dossier DAV [email protected]/0/Garçon La Note/
13:13:44 DAV [email protected] [CalDAV / CardDAV] Synchronisation des éléments: Synchronisation de DAV [email protected]/0/Garçon La Note/ terminée : 0 envoyés, 0 supprimés, 0 obsolètes, 16 éléments, 0 téléchargés
13:13:44 DAV [email protected] [CalDAV / CardDAV] Synchronisation des éléments: Terminé
13:13:44 DAV [email protected] [CalDAV / CardDAV] Synchronisation des éléments: Pour le dossier DAV [email protected]/0/Garçon La Note/
13:13:48 DAV [email protected] [CalDAV / CardDAV] Synchronisation des éléments: Pour le dossier DAV [email protected]/0/Etienne/
13:13:51 MailClient.Storage.Application.OperationException: Erreur de synchronisation du dossier CalDAV : System.ArgumentException: Kind property of dateTime is Utc but the sourceTimeZone does not equal TimeZoneInfo.Utc
13:13:51 à System.TimeZoneInfo.ConvertTime(DateTime dateTime, TimeZoneInfo sourceTimeZone, TimeZoneInfo destinationTimeZone)
13:13:51 à MailClient.Schedule.TimeZone.TimeZoneConvert.ConvertTime(DateTime dateTime, TimeZoneInfo sourceTimeZone, TimeZoneInfo destinationTimeZone)
13:13:51 à MailClient.Schedule.TimeZone.TimeZoneConvert.ConvertTimeToTimeZone(TimeZoneInfo sourceTimeZone, DateTime dateTime, TimeZoneInfo destinationTimeZone)
13:13:51 à MailClient.Schedule.ScheduleConvert.UpdateRecurrence(IScheduleObject scheduleObject, Calendar calendar, ScheduleComponent updatingComponent)
13:13:51 à MailClient.Schedule.ScheduleConvert.UpdateScheduleObjectFromComponent(IScheduleObject scheduleObject, Calendar calendar, ScheduleComponent updatingComponent, ScheduleConvertOptions options)
13:13:51 à MailClient.Schedule.Event.EventComposer…ctor(Calendar calendarObject, Event clonedComponent, IEvent parentItem, Boolean removeMethod)
13:13:51 à MailClient.Protocols.CalDav.Synchronizer.EventItemSynchronizer.CreateItem(Folder folder, Component payloadComponent, Uri uri, String eTag, CancellationToken cancellationToken)
13:13:51 à MailClient.Protocols.CalDav.Synchronizer.SynchronizeItemsCommand.CreateCalDavItem(Stream payloadStream, Encoding encoding, Uri uri, String eTag)
13:13:51 à MailClient.Protocols.CalDav.Synchronizer.SynchronizeItemsCommand.CreateCalDavItem(ResponseItem item)
13:13:51 à MailClient.Protocols.CalDav.Synchronizer.SynchronizeItemsCommand.DownloadItemsMultiget(IList1 uris, Boolean calDav) 13:13:51 à MailClient.Protocols.CalDav.Synchronizer.SynchronizeItemsCommand.ProcessItems(Dictionary
2 items, Boolean deltaSyncReport)
13:13:51 à MailClient.Protocols.CalDav.Synchronizer.SynchronizeItemsCommand.Execute(WorkerStatus status)
13:13:51 à MailClient.Commands.Command.Process(WorkerStatus status)
Thanks
