Button or Hotkey to mark as read
I need a button or hotkey to mark a message as read / unread.
The system setting to mark a message as read after a determined amount of seconds is good, but not sufficient.
The right click - mark as read/unread is good, but not sufficient.
There are some topics on this already, reoccurring request. I’d love to see it implemented. It’s a very simple task.
Thanks.
Hello, you can mark messages as read using a shortcut setup in Tools > Settings > General > Shortcuts, the default shortcut for this should be CTRL+Q for Read and CTRL+U for unread messages.
Hope this helps,
Oh wow, thank you.
Glad it works, let us know if you come across any other issues or questions about the application, we’ll be happy to help.
