Business card phone numbers
It seems that EMClient randomly selects which phone numbers to show in business card view. On contacts with more than two numbers, once they are entered in the edit screen, how do I select which two will be displayed on Business Card view? Even though I save the two on the edit screen that I would like displayed in Business Card view, it reverts back. And not all contacts have the same two (Home, Mobile) phone numbers showing, even those with three or more phone numbers.
Ideally, we’d be able to edit most parameters in business card view.
you can click on button with name of that number (home, work, etc…) and it will show drop down list where you will be able to choose what number you want to see.
Jan
Yes, I do that but then when I close the contact (after clicking on Save), it reverts back to what was showing previously. In other words, it doesn’t save the numbers that are showing in edit view when I close the contact and return to viewing it among the other contacts.
what service for contacts do you use? can you try to create completely new contact and then check on server if it has been synchronized?
Jan
I was happening to me too - culprit was Google Contacts - changed phone order there and everything is good.
