Bug: CalDAV organizer edit re-sends stale attendee PARTSTAT
Bug: CalDAV organizer edit re-sends stale attendee PARTSTAT → 403, then retries forever
Environment
  • eM Client 10.4.5326.0 (.NET 8.0.25), Windows 11 (10.0.26200)
  • CalDAV/CardDAV account against Open-Xchange (OX App Suite)
Summary
When I (the organizer) save an event whose attendee is NEEDS-ACTION on the server, eM Client re-uploads the whole VEVENT with that attendee’s PARTSTAT set to a stale ACCEPTED from local cache. OX correctly rejects it (RFC 6638 §3.2.2.1 — organizer may not change an attendee’s status) with 403. eM Client then re-issues the identical failing PUT every sync cycle indefinitely and won’t pull server state down, so the item is permanently stuck.
Repro
  1. CalDAV account on an RFC-6638-strict server (Open-Xchange).
  2. Be organizer of an event with an attendee the server holds as NEEDS-ACTION (here entity=-1 — server treats the address as external/unresolved).
  3. Edit anything (time/alarm) or let an alarm re-upload, save.
Expected: re-emit each attendee’s PARTSTAT as last reported by the server, change only organizer-owned fields; on 403, re-GET and rebase/drop.
Actual: uploads PARTSTAT=ACCEPTED for an attendee the server has as NEEDS-ACTION → 403; retries forever; never reconciles.
Log (redacted)
PUT https://dav.example.org/caldav//.ics
If-Match: “1002-13582-”
Content-Type: text/calendar
ATTENDEE;EMAIL=[email protected];CN=;PARTSTAT=ACCEPTED:mailto:[email protected]
END:VEVENT
→ 403 Forbidden
OX:categoryPERMISSION_DENIED</OX:category>
OX:error_descForbidden attendee change [id 13582, attendee …
partStat=NEEDS-ACTION, uri=mailto:[email protected], entity=-1 …
field PARTSTAT]</OX:error_desc>
The uploaded VEVENT says ACCEPTED; the server says NEEDS-ACTION.
Two defects
  1. Stale attendee PARTSTAT on organizer save (should preserve server-reported value).
  2. Infinite retry of a rejected change / deadlock (should reconcile on 403).
Comparison: Thunderbird/Lightning on the same server doesn’t do this.
It appears that I am getting a similar error when receiving accepted invitation emails. If I open/view the email response, (specifically in my case from a google calendar reply),I get the same permission denied response with the same error message.
This cannot be fixed without repairing the calendar in emclient to remove the upload, logging into the Open Exchange web interface, loading the accepted email in the web UI, and then syncing the calendar in eMclient.
This is a critical error for my use case and I either want a refund or this bug solved.
Note that other threads about event syncing issues reference either accepting updates from anyone or only accepting invites from known senders. I originally thought this was my issue, and added the email google uses for cal updates ([email protected]) as a contact. This did not resolve my issue.
Hi @shannon-patterson, this might probably be solved easier if you send the calendar logs to our VIP Support (https://support.emclient.com/) which you have access to.
