My emails sync but the calendar is empty. Any ideas what could be holding it back? It seems to have set the account up with IMAP and it isn’t flagging the Caldav address up as faulty, just doesn’t bring anything down from the cloud. HELP!
Actually don’t worry, it turns out the computer wasn’t uploading their calendar (IE it was local only). Logging into Yahoos webcaldav site and putting in some test events immediately sent them down to the EMClient calendar, proving EMC is working fine!
Hi, thank you for the update, if you come across any other issues or questions about the application, let us know, we’ll be happy to help.
Actually there is one issue I am still experiencing. When I sync the Calendar it is working, but it comes up with an error message saying ‘Error when synchronizing CalDAV folder: System.Argumentexception: Kind property of datetime is UTC but the sourceTimeZone does not equal TimeZoneInfo.utc at System.TimeZone.Info.ConvertTime’… and on and on. Any ideas welcome! Thanks
Hi James, what version of eM Client are you currently using?
