Birthdays not showing in calendar
Recently, the birthdays of the people I have saved in my contacts no longer appear in the em client calendar. They are visible in the “normal” MacOS calendar, in BusyCal too, and on the iPhone as well. They used to be visible in em client too, but now they are gone. Is this a new feature? Or can you do something about it?
If you are using Google Calendar the birthdays disappeared in Dec 2024 “due to a Google problem” as @Olivia_Rust advised in the post below. Unfortunately that has still not been fixed.
Aha. I don’t use Google Calendar, but apparently there’s suddenly the same problem with my provider. Well, yes. It seems there’s nothing you can do about it.
