Bigger Interface font
First of all, I am impressed with the software. Everything works flawlessly. I have only one issue. My vision is not the best. It would be extremely helpful if I could increase the font size on the interface. Also, I would like to make the email tiles on the left wider. After playing with the software for two hours, I could not find any options to fulfill my two needs. Is there a way to make the email tiles wider and the overall interface font bigger?
Sorry for the late reply, just registered to eM today.
I had the same problem. You can try on Menu->Settings->Appearance->Lists and then in the Fonts section, Select and change the font and size there.
