BETA 11 - MCP client name not changable - same MCP server names when using multiple PCs is confusing
If you are using em client e.g. on 3 PCs you want to be able to change the MCP-Server name, so that not every server name is “emclient”
Hi @TomRox, you should be able to fill in your own server name in your MCP server, “emclient” is just a default preset.
Or can you specify where/with which service you’re unable to do so?
Hi Olivia, thanks for your reply. It was also my first thought that I can just change the default text - but the field was not editable. There was a button next to the text field - i thought maybe this one is to make that field editable, but it was just “copy”.
Or am I overseeing/overlooking somehting (aka Tomaten auf den Augen ;-))
Thanks, tom
Hi Tom,
the field/text inside eM Client is just a template to help you with the setup in your MCP.
You can just fill in different name in your MCP configuration, you don’t need to copy the one from eM Client.
