Beta 11 issues (kb layout + printer paper size setup)
After Beta install, the keyboard layout keeps flipping back to English Canada from English US AND the printer dialog paper size keeps flipping back to A4.
There was printing and alot of other fixes in the last few Betas so try the latest V11.0.865 from the release history page and see if that fixes your issue. You can also try the “Check for update” in the Menu to update.
Note: Before updating make a manual backup via “Menu / Backup” incase you need to restore for any reason.
If you still have the same issue with the latest Beta then suggest you email the Beta support team at [email protected]
