Beta 11 crashing periodically
Hi, reporting a recurring issue with Beta 11 v. 11.0.473
Beta 11 (will post version number shortly) periodically crashes, about once a day or once every 2 days. Em Client is running when the laptop is on, about 16 hours/day. Today I was going to Save-All attachments from a message and em Client crashed. Because em Client did not close properly, it then checks for corrupted databases and inconsistent data which takes about 5 minutes for a restart of em client.
Windows 11 laptop
Having the same issue with 11.0.1054. Crashes after a few hours requiring a database check which takes a very long time to complete. Not an acceptable long term solution.
Hi Tony,
Sorry for the late reply, and thanks for the detailed report.
Since you posted, the final version of eM Client 11 (11.0.1054) has been released. If you haven’t updated yet, you can read more about it and download it here: eM Client 11 has been released | eM Client
To help us find the cause, could you please tell us:
  • Does the crash always happen when a file window opens (for example Save All, Attach file or Save As), or also at other times? In the other thread, you mentioned it also crashes when you click the Attach file icon.
  • When eM Client crashes, do you see an eM Client crash report window, or does it just close without any message?
  • Do you use any antivirus, backup, or other tools that modify Windows? If so, which ones?
If you do see a crash report window, please submit the report with your email address and reply here once you have, so we can find it. Please don’t paste the report into this thread, as it may contain personal details.
About the long startup: when eM Client does not close properly, it checks the database on the next start to make sure your data is consistent. This is expected and it helps protect your data, so please always let it finish.
Thanks David Gall.
I’ve been running v.11 release (not Beta) for the past couple of days. v. 11.0.11201 However, same issue with em Client unexpectedly stopping. Today I wanted to save an email as PDF and I Right-Click > Print then in the print dialog clicked Save as PDF. I needed a new sub-folder and when I clicked on New Folder and em Client suddenly closed on its own. No error message, no crash report. I’m restarting em Client and letting the check for database corruption run to completion. Antivirus is Windows stock Windows Defender. I run MalawareBytes. As for modifying Windows, hard to say as I have several utilities such as PowerToys and Synology Drive.
Next attempt, I opened a stand-alone instance of Windows Explorer to create the new sub-folder. Successful. Then back in the em Client Pprint > Save As dialog I could navigate to the new folder (just not create it) and successfully saved. Repeated Save as PDF and only navigating in the folder navigation dialog of Save as PDF.
Seems when em Client is in the print dialog > Save as PDF and tries to do any windows explorer functions such as create new folders, that’s when em Client crashes.
