Anyone having issues with a Fastmail account?
I keep getting this error message (from the logs as nothing shows in the “Errors” tab of the Operations window).
I deleted and recreated the account but same thing
Could you please enable IMAP logging under Menu > Settings > Advanced > Logging for the affected account, save the settings, and restart eM Client?
Once the error occurs again, return to the same section and click Send Logs. Please send the message to [email protected] and include a link to this forum thread.
Thank you.
Same with united domain IMAP.
same for me with united domains
Works for one session if the account in new, and fails the following day with:
19:15:27 Uhr xxx [IMAP] MailClient.Accounts.ConnectionException: Fatal error: invalid sequence
—> MailClient.Imap.Base.ByeException: Fatal error: invalid sequence
at MailClient.Imap.Base.Connection.TryParseUntaggedStart(LineSequence& line)
at MailClient.Imap.Base.Connection.ReceiveAsync()
at MailClient.Imap.Base.Connection.RunCommandAsync(Command command, Func3 notificationCallback) at MailClient.Protocols.Imap.ConnectionExtensions.RunSelectCommandAsync(Connection connection, String selectPath, FolderInfo folderInfo, Boolean condstore, Boolean annotate, QResyncSelectParameter qresync) at MailClient.Protocols.Imap.ConnectionPoolEntry.SelectFolderAsync(Folder folder) --- End of inner exception stack trace --- at MailClient.Protocols.Imap.ConnectionPoolEntry.SelectFolderAsync(Folder folder) at MailClient.Protocols.Imap.ConnectionPool.AcquireConnectionAsync(Folder mailFolder, Boolean noSelect) at MailClient.Protocols.Imap.ConnectionContext.CreateContextAsync(ImapAccount account, Folder folder, Boolean noSelect) at MailClient.Protocols.Imap.ImapMailSynchronizer.MoveAsync(Folder folder, IEnumerable1 items, Folder targetFolder, CancellationToken cancellationToken, Boolean checkGmailInboxTags)
at MailClient.Protocols.Imap.ImapMailSynchronizer.MoveAsync(Folder folder, IEnumerable1 items, Folder targetFolder, CancellationToken cancellationToken, Boolean checkGmailInboxTags) at MailClient.Protocols.Imap.ImapMailSynchronizer.MoveAsync(IItemMoveContext1 moveContext, Folder folder, IEnumerable1 items, Folder targetFolder, CancellationToken cancellationToken) at MailClient.Protocols.Imap.ImapMailSynchronizer.Move(IItemMoveContext1 moveContext, Folder folder, IEnumerable1 items, Folder targetFolder, CancellationToken cancellationToken) at MailClient.Protocols.Common.ItemSynchronizer2.<>c__DisplayClass33_0.b__0(WorkerStatus status, CancellationToken cancellationToken)
at MailClient.Protocols.Imap.ImapActionCommand.<>c__DisplayClass11_0.<.ctor>b__0(WorkerStatus ws, CancellationToken ct)
at MailClient.Protocols.Imap.ImapActionCommand.ExecuteInternalSync(WorkerStatus status)
at MailClient.Protocols.Imap.ImapActionCommand.Execute(WorkerStatus status)
AccountId = 10516339-3df9-40e5-b4d6-8854066d4797
AccountName = xxx
IMAP_SERVER_TYPE = Cyrus
RunInPlace = False
ByeException
RECEIVED_LINE = BYE Fatal error: invalid sequence
COMMAND = SELECT INBOX.Sent (QRESYNC MailClient.Imap.Base.QResyncSelectParameter ANNOTATE)
