Best way to reinstall eM Client
I need to reinstall eM Client. I understand there are two ways to do it…
  1. During the uninstall select “no” to delete data
  2. Reinstall from a backup
    Which is the best way to do it, or doesn’t it matter?
    thanks,
domingo 14 julio 2024 :: 1833hrs (UTC +0100)
You can use either, I prefer from Backup
To move your eMC data etc to a new computer
The best way to move all your data etc is through: Backup & Restore.
Follow these steps:
On the old device:
1./ Create a backup: Menu ->Backup
2./ Deactivate the license on this device: Menu ->Help ->License
3./ Find the .ZIP backup file and move it to your new device (with a USB)
The default location is …\Documents\eM Client)
On your new device:
1./ Install eMC (www.emclient.com/dist/latest/setup.msi)
2./Move the ZIP backup file to: …\Documents\eM Client (create the eM Client folder if it is not there)
3./ Having installed eMC skip initial setup
4./ Restore from your backup through Menu ->File ->Restore
5./ This will transfer everything to mirror your previous installation
6./ Activate your license in Menu ->Help ->License
¡Buena suerte!
skybat
